Balancing ET Drags w/ tubes
Got my new wheel/tire combo mounted / balanced today. I went with 15x10 Centerline Warriors with 26x10 ET Drags and tubes.
One wheel needed 4.5 oz. and the other needed 9 oz.
This HAS to be because of the tubes. All the weight was on the opposite side of the rim from the valve stem.
Does something sound messed up with this? With the same tubes and my old ET Streets / OEM wheels it only took like 2.5 oz.
No problem. You can't expect a wheel to be always exactly balanced when there are seperate components. Weld, material variance etc comes into play.
The important thing is that overall your rim is balanced in the end.
Steve
Steve
Actually, you would not feel one bit of a difference in balance as long as the wheel is balanced....even if it took a 1lb weight to balance it, it is balanced in the end and that is all that matters... *note 1 lb of weight added eats up hp/weight ratios away though as you are adding rotational mass to the rim.
