Which studs for Bogarts?
I want to run my ZR1's on the street and Bogarts at the track, but I want to upgrade my studs, what should I go with??????
Please give specs....part# or dimensions...
Thanks..
Thanks..
Stock studs are 1.5" long, go with a 2 inch stud if your concerned about passing tech. LS1 setups will miss passing by 1/4-3/8 of an inch.
They should still work fine with a closed lug on your stock rims (at least with a McGard closed 60 deg shank style lug...not sure about a stock lug). Essentially, you need <1/2" more then stock to pass tech using an open lug.
Steve
Steve
btw, if your running 12mm parts, then the only option you have is a 2.5" long stud, you can just cut them to fit with a metal handheld hacksaw fairly easily. Probably take you about 10 min to do. The only reason why I mention this is you won't need the extra length shank, and it will only interfer with stock lugs seating correctly.
arp studs are sold at summit for ~12/set. ARP-100-7708.
Definitly only choose a higher tensile studs.
