Has anybody used wheels from Vintage Wheel Works???
Has anyone used these wheels located athttp://www.www.vintagewheelworks.com/v45.html ?
I was just curious, they look good. But, they told me that in order to a get 50mm offset, the center sticks out about 1/2 inch. The most they can do without sticking out is 35mm. What do you guys think?
Carlos Villalon, Jr.
. . . I take it as the center portion goes beyond the lip below it.
http://www.netsnapshot.com/pcw/build...UNT=4394&KEY=7
Although I have questions for you. What size wheel? Reason I ask is because depending on your wheel size 50 mm offset may not be required.
Originally Posted by Xsta Z 28
Correct. Take a Look at the photos in ths Album (below), go down about 16 pictures to the shots called "Close up of front wheel center and hoop profile" and "Close up of rear wheel center and hoop profile" . Those pics should show you what they mean by the center will be past the center "hump".
I see exactly what he was talking about now. Thanks. I'm thinking that some 17 x 9.5's would do the trick. I was also thinking that I could probably get away with a 45mm backspace.
Torq Thrust 2's come with a 44 mm offset. FYI
