MT ET Street do not fit in stock wheel ??
Old 11-08-2004, 11:37 AM
jggarrid's Avatar
Angry MT ET Street do not fit in stock wheel ??
Hi I tried to use my new MT ET Street 26X10.5-16LT in the stock wheels (Camaro z28 1999), and the guy doing the labor tell me "they don't fit...the size is ok, but you need a special wheel"
Is this true????
Old 11-08-2004, 11:55 AM
Restricted User
2001 Pewter WS6's Avatar
That is what I am running but on Firebird wheels. It fits with lots of room to spare...
Old 11-08-2004, 11:58 AM
m1key99WS6's Avatar
I have 26x11.50x16 et streets on stock firebird rims and they fit perfect.
Old 11-08-2004, 06:52 PM
kotcls1's Avatar
Sounds like the guy doesn't know what he is talking about, I am also running those on my stock Firebird wheels with no problems other than keeping my 10 bolt from blowing up.
Old 11-08-2004, 06:53 PM
1999Z28's Avatar
yep, i got bfg DR's on a set and the same size MT ET's on another.
Old 11-08-2004, 07:58 PM
2MuchRiceMakesMeSick's Avatar
Take the rim and the tire to a different shop...a reputable shop.
Old 11-08-2004, 10:49 PM
The LT1 That Could's Avatar
slap him and call him a retard, then tell him to put `em on.....everyone has ran that size ET street on stockers at some point and time, lol!
hell, i used to daily drive a 26x11.5 on salad shooters (sadly)
Old 11-08-2004, 10:58 PM
blu98ta's Avatar
I have my 26x11.5x16's on stock camaro wheels. I agree, call him a retard and leave. If you can go to a Discount Tire, I got mine done there for $15.
Old 11-10-2004, 12:30 PM
1fastWS6's Avatar
He's probably saying that 'cause he can't get the beads to seat. The GM rims have a weird lip in the inside that makes the ET Streets difficult to get seated all the way. One shop tried for an hour on mine until I took it somewhere else. It finally seated by inflating it to like 90psi. I was standing behind a concrete wall with my sphincter puckered when they did that though.
Old 11-10-2004, 05:07 PM
Worm's Avatar
Uhhh
Man theres alot of violent smilies
Old 11-10-2004, 07:38 PM
Originally Posted by SDC
Uhhh
Yes there is...you forgot
Old 11-10-2004, 11:17 PM
1BAD02WS6's Avatar
I work in a tire shop, i do that all day long he should of had no trouble mounting those. he might of had a little trouble seating the bead but that is no problem for anybody that has done tires for more than a week.
as fare as inflating a tire to 90 psi not a big deal, but iv had tires blow up in my face rubber and wires slapping your face sucks a big one
Old 11-11-2004, 08:23 AM
jggarrid's Avatar
OK..."the retard" use 45 psi... what are the max psi that can be used?
Old 11-11-2004, 09:43 AM
1fastWS6's Avatar
It says on the tire "DO NOT USE MORE THAN 35psi to SEAT THE BEAD"
That's what had me worried when it took 90 to seat them.
Old 11-11-2004, 10:48 AM
Restricted User
NBM2001z28's Avatar
my nittos took about 90 too. U just turn around when you do it incase you blow up the tire some just dont like to go on at all. i took mine off the rim and even retried it then i was like... **** it and put more pressure in them
Old 11-11-2004, 11:20 PM
SlowTA's Avatar
it should fit fine...i guess he is just to lazy to make the effort to get everything needed to make it happen
