Guys with Nitto 555r's Drags
Old 11-09-2004, 03:57 PM
Tiremarx723's Avatar
Default Guys with Nitto 555r's Drags
How are they on the street? Can you corner on them ok? I am thinking of getting some 315/35/17's, so tell me about yours...
Old 11-09-2004, 04:11 PM
Zero30's Avatar
I LIKE MINE THEY STICK WELL AND THE TREADWEAR IS BETTER THAN THE et STREETS
Old 11-09-2004, 04:16 PM
how do they take corners? not that im autocrossing but i will hit a few corners fairly hard every so often. I think of drags, and i think of soffffft side wall, and i wouldnt want to lose a tire around a corner
Old 11-09-2004, 04:21 PM
2_wacko's Avatar
They are not as soft as you would think. They work fine I have hit corners at high speeds and they handle fine. You will be fine with a set.
Old 11-09-2004, 04:38 PM
Todd@AZPowerAndSound's Avatar
with normal street tire pressures I think they handle great. Some guys actually auto x on them while pumped up over 40psi. I love them
Old 11-09-2004, 04:53 PM
6']['9's Avatar
how much are they through DTD?
Old 11-09-2004, 04:57 PM
DTD Shows $158 for 275/40/17's and $182 for 315/35/17
Old 11-09-2004, 04:58 PM
6']['9's Avatar
thanks
Old 11-09-2004, 05:12 PM
No Prob, what is a good compliment tire for the front with nitto 315's in back? or does it even matter..should i just go to tire rack and read the reviews and select from that?
Old 11-09-2004, 09:29 PM
69TA's Avatar
I have them on my Firehawk (315's all around). They are awesome tires for the money. They handle just fine and with full tread they were even good in the rain.
Old 11-10-2004, 09:14 AM
2FAST4U's Avatar
I have Nitto 555R 315 in the rear and Nitto 555RII 275 in the front! My car has more 600rwhp on turbos only and can handle very very well with my setup! All I change at the drag strip is rear tire press. Stay away from rain and snow! But dry streets are awsome!
Old 11-10-2004, 09:38 AM
Shane's Avatar
I don't have anywhere near 600rwhp, but this is the setup I have too, with my puny ~400rwhp... Works great - street, strip, and autocross...
Rain isn't *too* bad when the 555Rs are fairly new - they do tend to hydroplane some though - mostly because they're like 4 feet wide...
Old 11-10-2004, 12:30 PM
2FAST4U's Avatar
yeah I was scared shitless when it started raining one day I was out! So I was driveing like a old lady! But it was fine, just had to control my right foot and trub the TCS on. No big deal.
Old 11-10-2004, 04:58 PM
WILWAXU's Avatar
They drive fine... once warm
On cold mornings they are a little slippery till they get a couple miles (heat) on them.
Old 11-10-2004, 05:03 PM
the predator's Avatar
a few seconds of = very sticky DRs. i've put 1k miles on them and have had zero problems in the rain. handle great on the street, handle even better once you have been driving around a bit just to get a little heat created.
Old 11-10-2004, 05:04 PM
Worm's Avatar
I can't tell a difference, honestly. 275/40zr17s.
Old 11-10-2004, 05:13 PM
5POINT7's Avatar
I went from bald 275 Kumho's in the rear to brand new 315 Nitto DR's and the difference was night and day. Felt like a whole new car. And I've got sfc's, lca's, torque arm, panhard rod, and eibach pro kit lowering springs.
I can floor my cammed formy around a turn and dead hook! And no more accidental chirpage of the rears, you've got to intentionally try to get these tires loose. I like my Nitto's on the street, but am looking forward to switching to BFG's soon (from what I hear, the BFG's hook even better).
Old 11-10-2004, 05:22 PM
my only problem with drag radials is what was said above about cold ground and cold tires. Once up to operating speed...they are fine
Old 11-11-2004, 12:15 AM
interesting, good to hear, thanks for the replies
Old 11-14-2004, 09:14 AM
2MuchRiceMakesMeSick's Avatar
Nitto 555r's is an all around good choice for daily driving / rain / last about 10-15k / and hook decent.
