need STRONG wheel cleaner!
Old 12-01-2004, 02:35 PM
the predator's Avatar
Default need STRONG wheel cleaner!
i just got done washing my TA from a drive from san antonio to houston. while i was cleaning my wheels i found on just only one of my wheels what appears to be road tar from the construction on I10. does anyone know what could take this off of my wheel without harming the finish? i've already tried wheel polish(mother's), rubbing alcohol, and goo gone. any other suggestions or ideas? any posts will be greatly appreciated.
Old 12-01-2004, 04:26 PM
WickEdSix98's Avatar
WD40 should work I would think
Old 12-01-2004, 08:46 PM
WickEdSix98-WD40. i will try that right away. thanks for the idea
Old 12-02-2004, 08:51 AM
Xsta Z 28's Avatar
Kerosene, or even bug and tar remover.
Old 12-04-2004, 04:59 PM
Xsta Z 28-thanks for the info. WD40 had little effect so on with the next idea. going to try a bug & tar remover. Kerosene is next. i hpoe one works!
Old 12-04-2004, 09:05 PM
6']['9's Avatar
wd40 will have little effect unless your trying to take rubber off your back bumper, you can try a bug n tar remover, googone or 3m Fine cut compound followed by some kind of wheel polish unless your using the regular silver wheels that came w/ the TA
Old 12-06-2004, 03:36 PM
c5blkvette's Avatar
tar is a derivative of oil refining... if all the above fails, you can try gasolene.
Old 12-06-2004, 03:43 PM
Flawless02SS's Avatar
i would try turtle wax bug and tar remover, it's safe for car paint so it must be safe for wheels. If that fails a KNOW brake fluid will do the trick!!
Old 12-06-2004, 04:26 PM
thanks for all the replies. the turtle wax bug and tar remover worked pretty good with a lot of scrubbing. im going to try some gasoline or brake fluid as mentioned to get the remaining tar off. hopefully that should do the trick.
Old 12-07-2004, 03:41 PM
gasoline did the trick. thanks to all that posted, i really appreciate it. the wheels look better than ever!
