Do I need to modify anything
Old 12-08-2004, 07:30 PM
WhosYourDaddy's Avatar
Default Do I need to modify anything
On a '98 A4 Z28, do I need to modify anything if I go with the 17X11 ZR1 wheels?
Thanks,
Kevin
Old 12-09-2004, 08:33 AM
Xsta Z 28's Avatar
Depends . . . sometimes you will need to do some inner wheel well massaging with a big f'ing hammer, and re-undercoat. If you are lowered may need to roll the quarter lip, although TA's have wider wheel well.
Do a search, a ton of info out there.
Old 12-09-2004, 07:48 PM
joeformula's Avatar
Also depends on what rear tires you get. Nitto's 315/35 fit about 1 inch smaller on an 11 inch rim. The BFG drag radials are a little bigger, you'll have to grind out the rubber jouncer and the aluminum plate about 1/8th inch to avoid rubbing.
