What size spacers do I need?
I have a 99 Trans Am with 99 silver C5 vette wheels. 17x8.5 front and 18x9.5 rear. They look ok on the front but the back looks tucked in too far. What size spacer do I need to install on the back to make it look right? No worries about stud length. I have ARP chromoly studs ready to put on and they are a 1/2" longer than stock. Help me out fellas.
Problem 2: I haven't installed the ARP studs on the back yet, but I have installed them on the front. After the new studs on the front my center caps won't fit on the wheel b/c the studs are too long. I need about 1/4 more clearance. Can I add a spacer to the front to correct this problem? Will it make my wheels look like turd in the front? Do I just need to cut the studs to length and not use the spacer? I prefer using spacers b/c I don't want to ruin the studs by cutting them down to length. I need some experience fellas and someone who has been through this before. Please help. :help:
UPDATE:
I just measured the amount of thread sticking out of the back side of the nuts on the front wheel. I have 5/8" of thread left on the stud that keeps the center cap from fitting on the wheel. After my measurements I have concluded that it would take at LEAST a spacer of 1/4" to 5/16" to make enough clearance for my center caps. How bad would this make my front wheels look? I would probably have to use the same spacer on the rear after I install the new ARP studs. At least this would make the rear wheels look right. I'm leaning more towards using a 1/2" spacer on the back.
I am going to buy my spacers on ebay and I know they are 5 lug, but what inch centers? 5 x 4.5" centers or 5 x 5" centers? I don't know what the bolt pattern is on the F body. I want to buy a good spacer that won't cause me troubles in the future.
I think that I may have an offset problem causing my disappointment with my vette wheels. I posted this in the "will it fit" thread. Someone please help.
I have OEM 1999 silver C5 Vette wheels (non Z06) on my 1999 Trans Am. The rear 18x9.5 wheels tuck in too far in the wheel well and look like crap! The front 17x8.5 would also look more aggressive if they would come out a little more than they do. What is the factory offset for these wheels? I just bought new tires for them with the plans to upgrade to the new C6 chrome wheels soon so I will be staying with the 17x8.5 and 18x9.5 setup. What offset front and rear do I need to buy to make my car look great?
I run a 245\45\17 on the front and a 285\40\18 on the rear. You may have needed to know that to help me. Thanks
I think that the front wheel would also look better if it were out a little farther so I think that I will use a 1/4" to a 5/16" spacer there. Are all of the spacers on ebay about the same quality or should I look for something in particular?
Just wondering if you got your spacer issue fixed. I can tell you what I've learned about these vette offsets. A 5/16th in the rear improves the appearance alot but I wanted it to come out even further so I got some 1/2" spacers and it's what I got in the rear. The fronts looked like they could come out after that by 5/16th's. I'm running 265/35's on all four though and am lowered so your look will be different than mine. With tires that tall I doubt you're lowered and with spacers you probably won't be able to lower it too much without rubbing.
1/2" in the rear and 5/16th's in the front is a sweet look for my car. BTW you can buy spacers at pep boys and they're not hubcentric. Just an aluminum plate that sandwiches between the wheel and hub.
Thanks alot for the reply. Yes, I read another post where someone was talking about 1/2" spacers in the rear for vette offset wheels. It may have been you. Thanks for the advice about 5/16" spacers up front. Sounds like a plan. I think that this will make my car 10 times better on the look.
Originally Posted by 777
i think you would want hubcentric
But I'm sure we could go all day talking about this though.
