Should I do 17x11s on rear?
Old 12-26-2004, 01:10 PM
BlkBrdWS6's Avatar
Default Should I do 17x11s on rear?
Hey guys! I'm going to be buying a set of TT2s in a couple weeks and am still trying to decide on sizes. My choices are:
17x9.5 all 4 wheels
or
17x9.5 on front, 17x11 on rear
I can get a pretty good deal on either, but there is one problem. I just bought brand new tires a month ago. They are 4 P275 40 17s. The main thing is I want to be able to use the new tires I have with the TT2s, but is it possible to fit a p275 tire on a 17x11? It doesn't seem like it would work, but it might. I know its not the ideal setup, but I figure that if I go with the 17x11 rear and use the tires up for now, I always have the option of going for a wider tire like a 315 in the future. So what do you guys think? Also, is there a lot of problems with 17x11s with 315s? Will I have to modify anything? Thanks a lot!
Old 12-26-2004, 01:31 PM
Onyx Z's Avatar
17x11's
Old 12-26-2004, 02:16 PM
69_YENKO's Avatar
Im fixin to get some 200s 17x11 on the rear of mine, i was told my 275 nittos will fit 11wheels. your 275's may also fit but there not going to look right. check with the tire manufacture about tire/wheel fitment.
Old 12-26-2004, 06:19 PM
joeformula's Avatar
DO NOT put 275/45's on a 17x11 wheel. Not only does it look like crap but it isn't safe. Sell or trade two 275/40's and get some 315/35's on the 17x11's. Having a wider wheel in the rear makes the car look good.
Old 12-26-2004, 06:38 PM
TooSlow02's Avatar
17x9.5 all 4 wheels
or
I have 17x11 in the back of my '02 Z28, no rubbing issues. You just need an adjustable PHB. Also, you can use the 36mm ZR1 offset, since the Pontiacs have a little more room in the rear wheel well. That way, you don't have to mess with the bump stops. (50mm offset requires trimming the bumpstops.) According to manufacturer's data, a 275/40R17 can safely be mounted to an 11" wheel, but it will be slightly shorter than if it were mounted to a 9.5" wheel. It won't really look right either. Like Joe said, swap 2 of your tires for 315s and get the 11" rears. You won't regret it.
Old 12-26-2004, 06:56 PM
skewba98z28's Avatar
Keep your 275's for the front and use two of them now and the other two when your fronts run out. Definetly get 17/11's in the rear with 315/35's they look killer.
Old 12-26-2004, 09:13 PM
5POINT7's Avatar
Get the 11's if you are not lowered. If you are, avoid them.
I'm lowered on my 17x11 ZR-1's and had to do a lot of bodywork to fit w/o rubbing.
17x11 tt2's will fit fine w/o any rubbing issues if you are not lowered...so get them and save the other pair of 275's for the fronts.
Old 12-29-2004, 02:13 AM
Jpr5690's Avatar
17 x 11 worked great for me i use 315 35 17 nitto 555r's looks nice not too much and great improvemnt in traction
Old 12-29-2004, 02:55 PM
D Rock's Avatar
Get the 17x11 on the rear and buy 2 nitto 315s then you will have a extra set of front tires for when those wear out.
Old 12-29-2004, 03:12 PM
Cyborg's Avatar
Go 17X11 and 315's. I think I have the 54mm GS offset which is what you want to minimize rubbing of the inner tire but with mine I still needed to do a little work (not much) with the BFH on the inner wheel well and I did some minor grinding on the bump stops. The look really good. Get some nice DR's too.
Old 12-29-2004, 03:18 PM
777's Avatar
buy some 315's and put em on the back...when your front's wear out put the other 275's you have on them what would really answer most of these questions is: look at the tire manufacturers recommendation...if it say 9-11" rim width...then you CAN put them on...if it says 9-10...then don't...it's that simple...i wouldn't run anything that isn't "recommended" it is recommended for a reason...remember that the 4 tires are what keep you on the road...that would be the last place i would test the limits...good luck...315's look real mean by the way
Old 12-29-2004, 03:40 PM
01 Red WS6's Avatar
17x11s thats easy. I went with 17x11s when I got my TT2s and I love them
Old 12-29-2004, 03:52 PM
777's Avatar
i don't know of anyone who doesn't
Old 12-29-2004, 04:12 PM
Slammed-am's Avatar
Period.
Old 12-29-2004, 05:53 PM
obseSSed's Avatar
Originally Posted by Onyx Z
17x11's
Old 12-29-2004, 06:12 PM
LS1SS4ever's Avatar
10.5 will be better
Old 12-29-2004, 06:56 PM
5POINT7's Avatar
Originally Posted by LS1SS4ever
10.5 will be better
See post #1.
10.5" is not an option.
Old 12-29-2004, 10:16 PM
jcarroll845's Avatar
What is the proper offset for the 17X11 on a 00 Camaro Z-28? I saw a few different options above and I want to be sure.
Thanks
Old 12-30-2004, 08:06 AM
Xsta Z 28's Avatar
Thanks
AS the "Does it fit" Thread states . . . 50 mm for ZR-1's and 45 mm for TT2's. . . . . .
Old 12-30-2004, 08:07 AM
Sorry. I missed that one. A link to the thread would be cool... but thanks for the info.
