96 series Weld ProStars
Old 12-27-2004, 09:24 PM
WJ SOM SS's Avatar
Default 96 series Weld ProStars
Do the 96 series Weld Pro Stars size 15x10 with 7.5" backspace require wheel spacers on '98-'02 F-Bodies with stock 10 bolt rear and stock calipers? Thanks. WJ
Old 12-28-2004, 12:38 AM
blkbeaZ28's Avatar
They will need wheel spacers and grinding or just alot of grinding.
Gilbert
Old 12-28-2004, 11:25 AM
WJ SOM SS's Avatar
.....Not what I wanted to hear. Thanks. WJ
Old 12-31-2004, 04:43 PM
STL2SLO's Avatar
All you have to grind on is the calipers right????
Old 01-01-2005, 10:12 AM
02WHITEZ's Avatar
can u get smaller calipers?
Old 01-02-2005, 12:23 PM
shaulinmathvader's Avatar
What backspacing do you need for prostars 15x3.5. Or what spacer do you need. A 1/4 inch spacers 3/8ths etc?
Old 01-02-2005, 10:50 PM
MIGHTYMOUSE's Avatar
5/16" spacer and i thought the fronts only had one bs 1" or somethin.
Old 01-03-2005, 01:15 PM
Retired Street Racer
Matt D's Avatar
for the fronts it is 1 3/4 in backspacing. if you use spacers, you do not have to grind. for the backs; if you use a 15x8, go with 5.5in BS, and 15x10 go with 7.5in BS. You can get away with not using a spacer on the backs, but it requires more grinding. in my opinion, you can't see the calipers ground up when you have the wheel on, so why not grind and save yourself the use of a spacer. here is a link to one of the other users homepage that i used a while back when i bought my prostars:Click Here
Old 01-14-2005, 10:38 AM
Derek98z's Avatar
Doesn't LT1 style calipers clear?
