lug nuts for weld prostar
Old 02-14-2005, 06:34 PM
ryansblk98ss's Avatar
Default lug nuts for weld prostar
I was wondering what size closed end lug nut I would need. I have 15x10 and 15x3.5 weld prostars. I was not going to run a spacer in back so it is the stock length stud but in the front i am going to use a 5/16 spacer so I am going with arp 2.5" studs.(will this be long enough?) Does any one know the size lug nuts I would need and where would be the best place to find them.
Thanks in advance for the help.
Ryan
Old 02-15-2005, 09:58 AM
LS1TECH Sponsor
Steve Burger's Avatar
I would run the open end Weld lug nut. You can get them from Billingsly >>> or Summit, Jegs. They are 12mm not sure on the shank length. These lugs are made for the Pro Stars.
Old 02-15-2005, 08:54 PM
Retired Street Racer
Matt D's Avatar
Here you go
Quick Reply: lug nuts for weld prostar
