new C5 rims/tires rubbing?
Old 02-28-2005, 12:44 PM
TigerWoodsJr's Avatar
Default new C5 rims/tires rubbing?
I just bought some OEM C5 rims and in the back when I try and throw the car sideways they are hitting the front inner fender. Is that normal or is something bunk with my suspension? its a 2001 btw. Do I just need to buy a spacer? Thanks for the info, im headed out the door to class or I would have searched.
Old 02-28-2005, 01:50 PM
Todd@AZPowerAndSound's Avatar
if they are oem...I figured the backs would run (the offset is too high) but the fronts should be fine
Old 02-28-2005, 02:17 PM
yeah, the backs are what rub ;[ Can I pound the fender in with a hammer or do I need spacers?
Old 02-28-2005, 02:37 PM
theyre rubbing at about the 10 oclock position right? BFH mod....Big freakin hammer. When you take the wheel off youll see exactly where it is. hammer that spot in a little bit (make sure your back seat is already up) and youll be good to go
Old 02-28-2005, 04:31 PM
jargan04's Avatar
I have OEM Y2K wheels. Just do the BFH mod, I did and it worked great.
