17 x 11 ZR-1 replica question?
Moderator
I am looking at a pair of 17 X 11 ZR-1 Replica wheels 50mm ofset. Also have a friend with some Nitto 275 40 17's will they fit on the 11" rims. from the stickey above it looks like only 315's will fit on these rims.
Well you probably wouldn't want to put 275s on an 11" rim, that will not look right and will be a beotch to get on...although they were designed for that.
On the other hand Nittos are narrower than BFGs so you would be fine, though with an 11" rim a 315 is a better bet in the long run if you race...
Originally Posted by Gallitin
I ran 285 Goodyear GS-D3's on 11" rim, but that type of tire is wider than most. With them on the rims it was completely flush tire/rim.
Hi Folks
I have 17X11 Replica rims that will have 315/35-17 BFG Drag Radial. I now have 17X9.5 with 275/40-17 Goodyear. I am would check with the tire MFG - I am not sure about 17X11 with smaller tires.
Bill
Bill
Originally Posted by Bill's 02 Z-28 SS
Hi Folks
Bill
Bill
Moderator
Not doing it after checking into it. I had a chance to get some 275 nito's cheap and some 17x11's also. Wanted to see if the combo would work. I really want to find a pair of Chrome ZR-1's to match my other rims, when I swap off street tires for DR's.
1 Post
Goodyears on 17x11
Originally Posted by alllooks
I'm going to find out as early as next weekend this answer and I have many opinions but here goes...I have 17x11 Fikse FM/10 wheels due to ship any day...here's the meat I have 315/35 F1 G3s and I meant to add the wheels are being manufactured with a 43mm offset...I also lowered with Hotchkiss springs about 1" (they claim) maybe a bit more...think i'll rub the tubs or fender "edges" with the Goodyears? I'm just looking for opinions if no "emperical datafied" answers are available.
