Best Drag Radial??
Depends on what you want out of the "best" drag radial. How are you going to use it?
Best as in hook, or best all around tire, or best tread wear....?
Here is a search on "drag radial" in this section. The 250 results should keep you busy and answer your questions.
https://ls1tech.com/forums/search.php?searchid=1398227
