Help matching sidewall height.....
Old 03-22-2005, 10:30 PM
nikkev's Avatar
Default Help matching sidewall height.....
Right now I have 285/35/18's (9.5" wheel) in the rear and 245/45/17's (8.5" wheel) in the front. Right now, the front sidewall is a lot higher than the rear. It was so noticeable, the wife even said something about it.I want to keep the 285's in the rear, what size on the front will match sidewall height? Thanks!
Old 03-22-2005, 10:40 PM
ritz's Avatar
Most likely a 245/40/17.
295/35/18 and 275/40/17's match pretty well and 275/40/17 and 245/45/17 have the same size sidewall. So if you have 285/35's you need to go with 245/40's.
Old 03-23-2005, 01:34 AM
Eugenio_SS's Avatar
275/35-18 and 245/45-17
Plus, they will fit well on the wheel sizes you have.
Old 03-23-2005, 03:12 AM
DaddySS's Avatar
The math says: 285*35% = 99.75mm
245*45% = 110.25mm
so 245* 40% = 98mm very close
Old 03-23-2005, 07:04 AM
ritz's Avatar
245*45% = 110.25mm
Yep.
Old 03-23-2005, 09:47 AM
nikkev's Avatar
Thanks guys! Just what I was looking for!
Old 03-23-2005, 11:46 AM
Eugenio_SS's Avatar
but the front ones are 17 and rear ones are 18... you need to look at overall diameter.
Old 03-23-2005, 12:07 PM
nikkev's Avatar
Overall diameter didn't matter to me. What matters is that the front rubber was noticeably thicker than the rear rubber between the rim and the fender.
Old 03-23-2005, 12:10 PM
00firebird's Avatar
i dont see why that matters, overall height is more important for driving
Old 03-23-2005, 12:15 PM
02Z06man's Avatar
245/40/17...that sounds about right to me
Old 03-23-2005, 04:06 PM
Eugenio_SS's Avatar
if that is the case,
get 245/45-17 and 275/40-18
I would think it's dumm to have a 17/18 combo if you care of the sidewall height and not overall diameter... just get same wheel size on all corners.
Old 03-23-2005, 08:33 PM
Tiger2o69's Avatar
I have those those and they are not the same size... My abs doesnt work..
So im going to try 245/50/17's..
http://www.miata.net/garage/tirecalc.html
Old 03-24-2005, 09:21 AM
Xsta Z 28's Avatar
Well when your ABS fails, it will matter . . . .
Old 03-24-2005, 02:57 PM
alan2000T/A's Avatar
Come on guys, I see where he's coming from.
Example: Z06 Vette wheel/tire combo is 265-40-17 Front; and 295/35-18 -rear that makes the aspect ratio/profile the same.
You know GM didn't design the Z06 to have different sidewall heights, but in order to accomodate that design, the overall diameter for the rear tire is taller.
Old 03-24-2005, 04:56 PM
Xsta Z 28's Avatar
Right. The Corvette is DESIGNED for different overall diameter tires, a Camaro is not, so the excessive OD difference will confuse the ABS computer in a Camaro and cause the brakes to fail in a panic situation . . .
Old 03-25-2005, 10:01 PM
markl67's Avatar
Exactly, you can't just compare sidewall profile if you're running different size rims (17 vs. 18). Check out the "does this fit thread" - there's a couple calculators where you can compare tire diameters.
Old 03-25-2005, 10:07 PM
ritz's Avatar
Well for the record I ran 17x9.5 and 18x10.5 with 275/40/17's and 295/35/18's with no problem on my TA.
Old 03-25-2005, 10:26 PM
ta12sec's Avatar
Smaller tries on the front will make the abs think the front tires are locking al release the front brakes......You want to guess I how know that .................
Old 03-25-2005, 10:59 PM
ritz's Avatar
I don't understand. There are plenty of guys running staggered set-up's. As long as the overall diameters are close then nothing will happen with your ABS.
Old 03-26-2005, 12:03 AM
ta12sec's Avatar
"As long as the overall diameters are close then nothing will happen with your ABS."
close and 1/2 inch diffrence are 2 diffrent things.
Quick Reply: Help matching sidewall height.....
