What PSI for Nitto Extreme's and 315 Drag's??
Old 03-27-2005, 02:01 PM
TACruiser's Avatar
Default What PSI for Nitto Extreme's and 315 Drag's??
What PSI should I keep my tires at with street driving and at the track?? I've got a 2000 TA, WS6 with Nitto Extreme's 275/40/17 in the front and Nitto 315/35/17 Drags in the rear??? Thanks!!
Old 03-27-2005, 06:06 PM
69TA's Avatar
Run normal pressure in the fronts and about 20-25 on the 315's (rear) and at the track you can lower it even more.
Old 03-27-2005, 06:10 PM
69TA's Avatar
Take a look at this post it should answer all your questions about tire pressure.
https://ls1tech.com/forums/wheels-tires/293090-disappointment-nitto-555r-s.html
Old 03-27-2005, 09:54 PM
TACruiser's Avatar
It's just what I was wanting to know. Thanks!
Old 03-27-2005, 10:03 PM
12stones's Avatar
on the track, make sure you heat them up good!
Old 03-27-2005, 10:24 PM
Phil99TA's Avatar
I've had problems wearing out the center of my Nitto's regardless of what psi I ran them at
Old 03-30-2005, 06:57 PM
Jimmy P's Avatar
My Nittos always wear uneven as well. I have only been through 3 pairs, but I have found that leaving them at 24psi makes them wear a little better. Maybe I can try a little lower like 22.
Old 03-30-2005, 08:52 PM
Moderator
davered00ss's Avatar
16 psi @ track.
