18x9.5 Z06 wheels need help
Old 04-05-2005, 07:49 PM
Z28LS1camaroguy's Avatar
Default 18x9.5 Z06 wheels need help
i am thinking about getting 18x9.5 inch Z06 rims all around, and ive been told that they fit and also that they rub and cause problems. i need some expert advice on this one and need to find out if they will fit. i am gonna get 285's on all fours and need to know if i will have any problems.
Old 04-06-2005, 10:13 AM
mistermiller20's Avatar
i have a 98 firebird with 18x9.5 zo6 replica's with a 56mm offset and 275's all the way around and have not had any troubles with rubbing but check the "does it fit thread" thats the best place to see if they will fit. its at the top of the wheels and tires forum
Old 04-06-2005, 10:15 AM
it says they should fit as long as the offset is between +50mm and +56mm
Old 04-06-2005, 10:16 AM
mySStery_machine's Avatar
It is all about the offset, he is right. If there are any other concerns though as well you can always check with Xsta Z, but the 56mm sounds about perfect.
Old 04-06-2005, 01:32 PM
trouse40's Avatar
Default wheels
i have 18x9.5 polished zo6 wheels 275/40/18 front 295/35/18 and it dont rub at all. im possibly about to sell mine, let me know if you are interested.
Old 04-06-2005, 03:34 PM
Xsta Z 28's Avatar
50 mm or 56 mm 9.5" wheels will not rub . . . . period.
Old 04-06-2005, 04:50 PM
ok thanks for the advice, i just didnt want to get the wheels and they dont fit or they rub and ruin the tires.
