Really Quick ? before I order!
Old 04-11-2005, 10:15 AM
moderate Z28's Avatar
Default Really Quick ? before I order!
Should I get closed end lug nuts or open ended for drag racing? There weld draglites. Thanks!
Old 04-11-2005, 04:50 PM
Xsta Z 28's Avatar
Open, give you the flexablilty for long wheel studs.
Old 04-11-2005, 05:54 PM
PRAY HRD's Avatar
open if you attend any event or just a by the book track with test and tune. once you get to a certain et, can't remember what that et is though, it's required. the lugs should pass through the lug nuts at least the distance of the diameter of the lug itself. example: if you're lugs are 5/8", then they need to stick through the nuts at least 5/8" as well. hope that helps.
Dave
