Did a search, but? Can I fit 275/60/15 on a camaro
Old 04-23-2005, 12:48 PM
TS6
TS6's Avatar
Default Did a search, but? Can I fit 275/60/15 on a camaro
I want to run 275/60/15 on my 2002 camaro, Mt drag radials most likely, will they fit or rub the bumper or????
Will be on a 15X8 rim with 5.5 BS BTW.
Thanks
Old 04-23-2005, 07:43 PM
slyws6's Avatar
The tire size should fit however I don't think 15in rims clear the brakes on our cars, unless you have shaved your calipers.
-Sly
Old 04-23-2005, 08:52 PM
Griswold's Avatar
I think they would fit. I used to run 15x8 pro stars (with the calipers ground). I had a nitto drag radial 275/50/15. My car was lowered with a prokit and I never rubbed them.
Old 04-24-2005, 03:51 PM
Stone0fFire's Avatar
has someone done a writeup
how to ground the calipers to clear 15's
without screwing things up?
i just made a post about this recently.
i want to run 275/60/15.
damn it.
Old 04-24-2005, 04:00 PM
-1SLOWSS's Avatar
You can run those tires, you just need to either
a) grind down your calipers a little or;
b) buy different wheels that fit without grinding like Convo Pro's
Here's a pic of GM Muscle's caliper after grinding to give you an idea of what to do
Here's a link to the thread: https://ls1tech.com/forums/showthrea...nding+calipers
Old 04-24-2005, 05:39 PM
TS6
TS6's Avatar
I know the brakes need to be ground, my question is whether or not the 28" tire will fit.
Old 08-11-2005, 02:18 PM
BLWN1's Avatar
Any updates?
Old 08-11-2005, 02:35 PM
LS69TA's Avatar
Someone did it here a little while back, but I think it was a 10" rim. Looked pretty good. They might be close to rubbing around the bumper cover though.
Old 08-11-2005, 02:42 PM
Mike's 01WS6's Avatar
There was one companys rim that I belive cleared the calipers in a 15" size without grinding but I dont rember which one it was. I wanted to buy a set of these for the ws6 when I had it.
Old 08-11-2005, 04:25 PM
LS69TA's Avatar
Centerline Convo Pro's or Warriors, or Bogarts.
Old 08-11-2005, 05:03 PM
TS6
TS6's Avatar
I put on a 325/50/15 on a 10" rim 7.5" BS. I did trim the bumper cover just a hair, you'd never notice it. Its all good, barely had to do anything.
Old 08-15-2005, 08:33 PM
cool.
what did you use to trim the bumper?
i have 295/50/15 on 15x10" w/ 7.5"bs
and it makes weird sounds and smells funny
when i have fat people in the back and take a corner hard
Old 08-15-2005, 10:01 PM
TS6
TS6's Avatar
Grinder, but anything will cut it. Its just plastic.
Quick Reply: Did a search, but? Can I fit 275/60/15 on a camaro
