01 GM Z06 Wheels
Old 05-14-2005, 01:55 PM
LS1ownzYOU's Avatar
Default 01 GM Z06 Wheels
Do 17x9.5 and 18x10.5 01 GM Z06 wheels bolt onto a 2000 Z28 with out rubbing or offset/backspacing issues? If I just took the wheels/tires to tire kingdom would they know how to make it work?
Old 05-14-2005, 01:57 PM
oodahss's Avatar
what size tires?
Old 05-14-2005, 01:59 PM
LS1ownzYOU's Avatar
the widest w/ the lowest profile i can use, that will maintain the stock ride height so it wont **** with my spedometer/odometer.
Old 05-14-2005, 02:15 PM
oodahss's Avatar
i have 295/35's in the back and i used an 8mm spacer, no rubbing, looks great!
Old 05-14-2005, 02:22 PM
LS1ownzYOU's Avatar
Do you have the motorsport replicas? Im talking about OEM GM z06 2001 wheels.
Old 05-14-2005, 04:10 PM
LS1ownzYOU's Avatar
no one knows?
Old 05-14-2005, 05:02 PM
dug
dug's Avatar
I think Mike K had some OEM z06 wheels for sale. He posted some pics on a camaro with no spacers with 305 35 18 nitto dr in back. Tucked in nicely.
Old 05-14-2005, 05:04 PM
dug
dug's Avatar
https://ls1tech.com/forums/showthrea...1&page=2&pp=10
Old 05-14-2005, 05:40 PM
Wyckedcamaro's Avatar
my aftermarket OE Concept 18x10.5 295/35/18's had to have the bump stop GRINDED OFF! plus a spacer to make it work.
Looks PHHHHHAAAT~!
Old 05-14-2005, 05:41 PM
ddelallata's Avatar
they'll fit without any problem if you lift up the car from the axle(differential). If you don't lift it from the center the rear bump stop will get in the way. A 5/16'' spacer gives you enough clearance to put the wheels without having to lift as mentioned above, but its a wise choice to upgrade to longer wheel studs. If interested I have two 5/16'' spacers for 25 dlls shipped. Check out my Cardomain site (link below) for pics of my car with OEM Z06 wheels with 2/16'' GM spacers.
Old 06-13-2005, 11:28 AM
white01ss's Avatar
Where'd you get those 1/8" wheel spacers? Smallest I could find is 1/4". Are they billet alum, steel, or the cast alum?
