??? ABOUT WHAT I NEED FOR ZR1s....
I am getting some 17x9 fronts and some 18x11s on the rear, need to know what spacers i need, and if i need to hammer my inner fender. the rims already have 315s on them.. stock springs...its a 2000 z28.............
Offsets???? Can't answer the question with the info provided . . .
But I'll take a guess. . . . fronts should be fine with a 275/40ZR17 tire.
Rear, are you sure they ar 18" wheels??? Never heard of a 18" x 11" ZR-1, so I will guees they are 17" x 11", which come in one of two offsets 50 mm, which fit really nice, alough some inner wheel well massaging will need to be done, or the other offset is 38 mm, which will not fit a Camaro, they will stick out of the wheel well, on a Firebird the 38's do fit, but quarter lip rolling may be required.
FYI search would be your best friend since there is a TON of ZR-1 wheel info out there.
THEY ARE ONLY 17 10.5 IN THE REAR AND THEY FIT FINE, WAS JUS BEING TOLD WRONG INFO............
