What 15" rims will fit 2002 without grinding the calipers?
Just got a 2002 Camaro SS and would like to put some 15" wheels on with drag tires and have heard that Centerline Convo Pros and Centerline Telstars will fit the front and rear without any grinding on the brake calipers. Anyone use them before or know of any other 15" wheels that will fit?
Bogarts if you can afford them. The Centerlines fit fine without grinding, but you can only get a 15x8.5 I think for the rear. You can get the Weld's, but you'll have to grind the calipers or run longer studs and spacers.
Thanks for the replies! Anyone running 15" Centerline Telstars? They're beginning to grow on me. If I get 15x8s, will 5" backspacing be the best bs to use? The 15x10s only go to 5" bs so I don't think they would work with that little bs on a 10" rim
