pro star wheels.. *need help
Old 07-02-2005, 02:56 AM
Fahad's Avatar
Question pro star wheels.. *need help
What is the backspacing size for the 15 x 4 front and for the 15 X 8 in the back?? I need everythings for the pro star wheels to be fit on my Camaro please..
Thanks
Old 07-02-2005, 09:35 AM
LS69TA's Avatar
15x3.5" in the front with 1 3/4" b.s.; 5,5" b.s. on the rear.
Old 07-02-2005, 01:03 PM
Fahad's Avatar
What about 15x4" in the front?? i need just the backspace size for the front and i want to know all installation Kits for weld wheels to be fit on my camaro.
Old 07-02-2005, 02:10 PM
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,087 Likes on 716 Posts
15x8/5.5 back.
15x10/7.5 back.
15x3.5 1.75
Fahad's Avatar
15x8/5.5 back.
15x10/7.5 back.
15x3.5 1.75
What is backspacer size for 15x4" in the front?? are you sure for the 15x3.5 is 1.75?? because i ask some guys in different forum they said. the backspacer for 15x3.5 is 1 3/4".
I need 4" for the front so which one will be fit on my Camaro??
Pro Star 96-Series Wheel
Size; 15'' x 4''
Bolt Circle: 5 x 4-1/2''
Rear Spacing: 2-1/4''
or
Size: 15'' x 4''
Bolt Circle: 5 x 4-3/4''
Old 07-02-2005, 02:41 PM
Tally TransAm's Avatar
your kidding right, 1.75" = 1 3/4"
and your bolt circle is 5-4.75
Old 07-02-2005, 03:54 PM
Fahad's Avatar
no... because i added the digits to some and i forgot this sorry..
I need the quick answer's. because SummitRacing are waiting from me the size's of backspacer and want to finish the order.. please...
Old 07-02-2005, 10:29 PM
LS1Tech Co-Founder
I think 15x4's only fit certain year F-Bodies. They won't fit 98+ for sure. I run 15x3.5 with 1.75 backspacing, a 5/16 spacer, and no brake clearancing.
Old 07-03-2005, 01:48 PM
01 Red WS6's Avatar
why not just go with the 15x3.5? 15x4 isn't much bigger. why do you need the 15x4?
Old 07-04-2005, 07:47 AM
Fahad's Avatar
well.. with 15x4 you will get better size for tires, more safe on turns also the holes on the streets, the car for weekend drive some times and mostly for track.
Old 07-04-2005, 10:34 AM
Retired Street Racer
Matt D's Avatar
i drove with 15x3.5 in front and 15x10 with full hoosier slicks 120 miles roundtrip no problem. you will have to grind a lot and go with a big spacer to get those 15x4 to fit. they will prolly stick out a bit as well. just go with a 15x3.5.
Old 07-05-2005, 02:08 PM
Fahad's Avatar
Maybe i will change my mind to 3.5" in the front.. I'm stopping now at back side size 8" or 10"
Old 07-05-2005, 02:16 PM
jamnut's Avatar
If you run a 15" x 4" you will probably have to grind your calipers. I have a friend that went with 15" x 4" and had to grind his front calipers. I run the 15" x 3.5" with 1.75" bs & 5/16" Spacers & didn't have to grind a thing.
Old 07-05-2005, 03:03 PM
Fahad's Avatar
check out this pic. is that pic same your friend calipers??
