My 11" ZR1's hurting
I know this is a very common problem with rear 11" ZR1's, the fender and tire rubs when ever I go over a bump, That and since the car has been lowerd it makes it even worse, Ive been thinking of just putting the stock suspension back on but not sure if I should do that or not. Or is there a way I can prevent that? The tires are starting to shred because of the fender its getting slashes and all. I was about to buy some new Yokohama ES100's but I dont know to spend so much money for tires for them just to be getting slashed and then one day blow out.
BANG THAT ****!! You just cant be scared. Grind the jounce bumpers and spacers on there. After all the banging is done, Buy some rubberized under coating and spray on the damaged part. It should look good as new.
