What 15" wheels fit over the rear calipers
I've done some searching and can't find the answer. I have a pair of 28x11.5x15 ET Streets that I'd like to run at the track but I dont want to grind the calipers. Is there a wheel that will work without grinding or do I need to just go ahead and get some 17's?
Originally Posted by LS69TA
Bogarts, or if you can get Centerline Warriors or Convo Pros but they only go up to 15x8.5".
MT reccomends those 28x11.50 to be on 8" rims so the 8.5's would do nicely
Originally Posted by SS2win
hmm I like the convos but the backspacing sux. gonna contact sjm and see if the RR bogarts are in the buget. (like anything is..)
SS, the RR series is a different style rim then what you initially considered. Give me a call to see what your specific goals are so I can setup in particular what meets your goals. (The RR rims are more expensive due to the material and setup that is involved).
Steve
hey man, found u a set of telstars
rears - https://ls1tech.com/forums/lsx-parts-sale/352163-sale-telstars-slicks.html
fronts - https://ls1tech.com/forums/showthrea...12#post3227812
Telstars will require alot of grinding on the calipers. More than with the Welds, and the Welds take a ton of grinding.
welp, ya learn sumthin new everyday...go with the Convo-Pros if youre on a budget, i know a guy selling some black powder coated skinnies for 260...might get in touch with him.
http://racelubbock.com/groupee/forum...6/m/5991087831
