MT E.T. Street's on Weld Racing...
...are they too hardcore for the stock rear end to hold using a TCI 3400 stall converter. basically everyting else is stock ecept for the lid and catback.
you'll be alright for a while. the ten bolt will slowly fall apart, more than likely the stock posi will crap out on you first. be sure and put in a much better aftermarket replacement, such as Eaton, or Auburn. If you can find a used SLP HD Zexel Torsen take off differential, those work pretty well also. axles should be fine, same with housing well into the 11s. Sub 1.5 60' or so should warrant the thought of a 12 bolt/9".
with that 3400, you should be just fine!
