Drag Rear Wheel Question....
I am thinking about getting some 15" rear rims for drag use only. Is there any wheel that will not require grinding the brake caliper other than Bogart? Will a 15X10 wheel fit? I would imagine it will since I have 17X11 on there now. What back spacing is needed for a 10" wide rim? What about a 8"-8.5" wide rim?
If it matters I am thinking of going with a 26 or 27X11.5X15 tire.
Thanks for any info.
Not sure which ones the 05/06's are, but the Convo Pro's will fit w/o grinding, but they only go up to 8.5" wide and stick out ghetto style. The Warrior/Convo Pro's are the only ones that will fit w/o grinding the calipers or running spacers. For a 15x10, you'd have to get Welds, and grind the calipers, or run spacers & longer studs.
Haven't seen anybody running them, but I believe those and the Telstars require alot of grinding to fit the LS1 cars. I was going to get Telstars, but I read somewhere that they required more grinding than the Welds, and the Welds require alot.
