<<<BEST STREET TIRES>>>
Old 08-22-2005, 08:28 AM
s.o.m.SS's Avatar
Exclamation <<<BEST STREET TIRES>>>
for a daily driven 02 ss camaro with 400+ rwhp... overall good handling, tread life and sticks when rpms jump up and dont float in the rain... lmk
Old 08-22-2005, 11:48 AM
FIREHAWK #07's Avatar
http://www.tirerack.com/tires/tires....e1=yes&place=3
work well in the rain. . . .
Old 08-22-2005, 02:34 PM
s.o.m.SS's Avatar
Originally Posted by FIREHAWK #07
thanks, do you own them? if so how do they hook in dry weather and is it worth $200 a peace? as far as tread wear
Old 08-22-2005, 03:01 PM
ZEEMAN's Avatar
I have had my GS-D3s on for about a month and absolutely love them
Old 08-22-2005, 03:16 PM
yup, just bought some. . . went to discount tire and had them price match the online tirerack.com. . . . plus he's also an ls1tech.com member
have not yet tried them in dry, but heard they work very well. . .
Old 08-22-2005, 03:20 PM
777's Avatar
Goodyear gs-d3's
Old 08-22-2005, 06:19 PM
Arachnotron's Avatar
I have GS-D3's on my daily driven Z28.
Old 08-22-2005, 07:25 PM
Roarin_8's Avatar
GS-D3s, the best STREET tire.
Old 08-22-2005, 10:35 PM
52172's Avatar
it sucks they don't make a 295/35/18 to put out back!
Old 08-23-2005, 08:40 AM
silver02ss's Avatar
Default yokohama avs es/100
of the three differnt dires i've had on my 02 SS (Goodyear Eagle F1 oem, Sumitomo HTRZ II, and the yoko's....i'd recommend the Yokohama's.
the eagle's just don't grip near as well and don't end up lasting as long, b/c i end up sliding all over the place scrubbing extra rubber off. so if you aren't an agrresive driver you may not have that issue...but they are too expensive for as long as they lasted me. the sumitomo's are the cheapest, good grip, but have a pretty soft sidewall. the yokohama's in my opinion are the best, excellent traction both wet and dry, with stiffer sidewalls.
grip
gy - low wet and dry - $~200
sumi - good wet and dry - $110
yoko - best wet and dry - $130
handling feel
gy - direct feel, quick turn in
sumi - softer, flexible, slower turn in
yoko - direct feel, quick turn in
sound feedback
gy - high pitch squeel
sumi - no squeel, just a 'scrubbing' noise of the rubber on the road
yoko - a subdued squeel
Old 08-23-2005, 09:21 AM
Hennytime's Avatar
does anyone run these on a stalled auto around a 3600rpm speed?
Old 08-23-2005, 10:32 AM
s.o.m.SS's Avatar
grip
handling feel
sound feedback
thanks
Old 08-23-2005, 11:25 AM
LS1Tech Sponsor
Superman09's Avatar
I have the Bridgestone Fuzion ZRi's and like they a lot so far. I get good traction, seems to not wear very much but they are still pretty new. No problems i nthe rain so far. Seems like a very nice tire. They stick pretty good and i only get a little squak in my 1-2 shift.I got a nice smoke show from my donut the other day too, pretty sweet. I ahve 245/40/18s up front and 265/35/18 out back. Cost $725 mounted and balanced from Firestone.
__________________
Featuring 6 different turbo kits for your F-body!
Check us out on Facebook at: www.facebook.com/HuronSpeed
Old 08-23-2005, 10:20 PM
The Sad's Avatar
Another vote for Fuzions ZRi's here.
Old 08-23-2005, 10:40 PM
ritz's Avatar
I did my research and I'm buying Fuzion's. They're 1 point away from GS-D3's as far as "Wet traction" goes, but these days they don't make tires that handle like **** in the rain unless it's a slick.
Besides when rain hits the ground it's time to let off the go pedal anyways.
I've seen 1.7's cut on ZRi's.
Old 08-23-2005, 11:37 PM
s.o.m.SS's Avatar
no ****, ill look into those... whats the tread life?
Old 08-24-2005, 06:44 AM
2000WS6Vert's Avatar
I've got about 14,000 miles on my ZRi's right now, I think I can get at least 18k out of them....and I'm a very hard driver....every turn is a chance to punish my tires!
Old 08-24-2005, 07:41 AM
XtremeBBQ's Avatar
another for gsd3's. things are absolutely amazing in the rain. but i cant get them to hook for anything personally. kinda dissapointed there cause i was told they were in the same hookup region as nitto dr's almost.
from a 1st gear roll punching it...all over the place, going into 2nd at 4k and bust loose again then chirping 3rd for a bit..
on an almost stock car? maybe i just need to shift at a lower rpm.
