Which lugs with Prostars and stock studs?
Old 08-23-2005, 12:43 AM
BADFNZ's Avatar
Default Which lugs with Prostars and stock studs?
I'm going to grind enough on my calipers to avoid using a spacer and aftermarket studs. Which lugs will I need? I've done plenty of searches and am still confused. I see the 12mmx1.5 but then I see different shank lengths. Do I go with the longest possible (1.365 on Jegs website)? Do I need to order washers with them? I need help
Old 08-23-2005, 01:18 AM
Zepher's Avatar
The longest ones may be too long and hit the rotor hat before locking down the wheel.
Take your wheel to a place that sells deep shank lug nuts and find the right length and then order those. 12x1.5mm is the thread pitch of the stud.
Old 08-23-2005, 02:06 PM
BADFNZ's Avatar
Do they need to be open end? I keep hearing some yeses and some noes.
Old 08-23-2005, 02:38 PM
Zepher's Avatar
they don't have to be, but I would go with open ended so you can see how far the lug goes down and if you get longer studs you won't have to buy new lug nuts.
Old 08-23-2005, 05:43 PM
BADFNZ's Avatar
Ok thanks for the help. I narrowed down which lugs I need, but since I'm not using a spacer like most do, I'm wondering if the 1.38" shank will be too long. I hate to buy a set and them not work.
Old 08-23-2005, 07:05 PM
Tally TransAm's Avatar
http://store.summitracing.com/partde...7&autoview=sku
Old 08-24-2005, 08:48 AM
Zepher's Avatar
I decided to snap a few pics of stock wheels with longer studs so you can see how they'll look, these are 3.5" GM studs,
Quick Reply: Which lugs with Prostars and stock studs?
