245 on an 18x9
Old 02-23-2006, 12:52 PM
98a4z28-410rwhp's Avatar
Default 245 on an 18x9
can i mount a 245 40 18 on my 18 x 9 rebels. it is a somotito (or something like that) so it runs a little wide its probly more like a 252 ish width. will this side wall fit in my 98 camaro without problems. thanks
Old 02-23-2006, 05:35 PM
carado1984's Avatar
yes but i dont know why you would want to do so.. tractions not going to be great.. and i believe you can run a 235-285 on a 9"... my buddy has 235s on his 5.0 which has 17x9's and the lip of the rim sticks out a little.. i would shoot for 265s
Old 02-24-2006, 08:21 AM
Xsta Z 28's Avatar
265 is the smallest tire I'd run on a 9" wheel . . .
Old 02-24-2006, 11:04 AM
i ended up buying the 245 due to the price and i have a 40 sidewall i got the skinnier tire to deal with the offset problems that rebels are known for. if it seems unsafe when i get them put on the store said they will let me return them for another tire as long as i don't leave the shop. do you guys think the 275 or 65 will rub on the rebels? i'd rather have a skinnier tire than a shaller side wall(ive had problems with 35 sidewalls)
Old 02-28-2006, 11:32 AM
Hugger Z's Avatar
It depends more on your offset than your sidewall as far as the tire rubbing. There is a sticky at the top of the forum that has a picture of different offsets and where the edge of the wheel will end up relative to the edge of the fender. Very useful.
As for the tire, if you have a 9" wide rim, I would stick with Xsta Z 28's advice and not go narrower than 265's. I believe the stock SS wheels used 275's on a 9" wide rim. Hell, I have 245's on my stock 8" wide wheels so they would definitely not fit right on your 9" wide rim properly.
