Gettin' slicks & skinnies Need advice on size!
Old 03-02-2006, 10:24 AM
extreme01ta's Avatar
Question Gettin' slicks & skinnies Need advice on size!
I've read and searched on here for a couple of weeks with no results so here's my question. What dia of slicks do I need and what dia for the fronts? Looking in jegs and summit they list a bunch of sizes for the front. Is bigger or littler better for the front. I understand that the Dia. of the rear will affect my RPM through the traps but is there a way I can calculate what size I need with my gear ratio etc. I'm getting a set of Bogarts and need to figure out what tire to run before I order my wheels. This will prety much be a dedicated track setup but I was thinking MT E/T streets just incase I need to pick on the locals on Fri. & Sat. night Mods are in sig. any advise on tires and especialy tire size will be very welcome
Old 03-02-2006, 02:52 PM
Anybody out there with any info? maybe post what you are running with you combo and results.
Old 03-02-2006, 04:13 PM
Derek98z's Avatar
judging by your mods, I think you will want a 26" tall et street (probably 26" x 10.5 x 15"). For the fronts, 25"-26"
Old 03-03-2006, 11:03 AM
Anybody else?
Old 03-03-2006, 11:36 AM
LS69TA's Avatar
Old 03-04-2006, 11:10 AM
LS1TECH Sponsor
badpewter-z's Avatar
26x10.5x15 rear
front 165r15 if you want something for street use to otherwise keep it the 26" tall
Old 03-15-2006, 06:05 PM
Anybody else? Also is it a good idea to run the et streets on the street or should I go with the et street radial?
