Tire size, what u running
Old 03-04-2006, 07:40 PM
radz's Avatar
Default Tire size, what u running
Wanting to put some big rear tires on my WS6. I have the stock wheels 17X9.5 and would like to run something bigger than the stock 275/40/17 tires. What would you guys suggest. I will put a spacer on if I need to, but I dont want to but wider wheels I just want some more traction. Any input would be great.
Old 03-04-2006, 07:43 PM
SSilverSSurfer's Avatar
your pretty much maxed out on tire size......read the sticky about 315's do not fit on 9.5 inch wheels....ihave 275/40/17 on front and 315/35/17 on the bak with 11"wheels
Old 03-04-2006, 07:51 PM
00tals1's Avatar
I have 17x9.5in ZO6 rims. Im running 285/40ZR17 GoodYear Eagle F1 GSD3. I like these tires alot. They are great in the rain. They are wide too. If I have the money I will buy again if not. Ill get the KDW's or Kumho MX in the same size.
Old 03-04-2006, 07:53 PM
radz's Avatar
Would 295's fit. does anyone even make them?
Old 03-04-2006, 08:39 PM
Mark A. Rogalski's Avatar
285/40/18 on the WS6. Stumbled into a limited private run of Michelin Pilot Sports in this size. No rubs or issues.
Otherwise I have been running 275/40/18 P-Sports's because when you jump up to the 285 (40 series 18") there are only 3 choices, Pirelli, Toyo, and Bridgestone.
One thing worth noting at least in the 40 series 18" tire. When you go up to the 285 from a 275, the sidewall transition seems to be more rounded transitioning to the tread (not squared off as much). I noticed this big time on the Toyo Proxes T1 285's and even so on the 285 P-Sports. I have not looked at the newer Toyo's T1R or T1S.
Old 03-05-2006, 11:14 AM
Xsta Z 28's Avatar
Exclamation
Nope. 285 is about the widest you can go within manufacture's recommendations . . .
Old 03-06-2006, 12:07 PM
NxLS1496's Avatar
does anyone have any pics of 285's?
Old 03-06-2006, 01:21 PM
LS69TA's Avatar
BTW stock WS6 wheels are 17x9.
Old 03-12-2006, 03:22 PM
52172's Avatar
17x9 with 265/40/17 Toyo Proxes T1-R
18x10 with 295/35/18 Toyo Proxes T1-R
