tire rotation question?
Im going to be getting new wheels an tires for my TA soon, i can't decide if i want larger wheels an tires in the back than the front, i dont know if this will be practical for me, what do you guys do about tire rotation? is this more costly to do this than if i had the same sizes all around? thanx?
It will definitely cause your tires to wear faster if you can not rotate them. If money is a definite issue, you may want to stick with the same size all the way around. On the other hand, if you want your car to stand out and look hawt, get the back wheels at least an inch wider. It will cost you in the long run, but you'll be happier with it. IMO
