275/40/18 on F-body
I have thoses on my rears. The fit is fine no rubbing what so ever. I have them mounted on Z06 wheels 18x9.5 they are about 1/4 inch wider than 274/40/17.Sorry I dont remember the offset, 53mm-56mm not for sure!
I have no clue what my offsets are either. But Ive got 275/40/18s all around and I love 'em.
Stock height, no rubbing what-so-ever. That and I like the extra bit of height the 40 offers vs the 35 @ stock height. Its not an astronomical distance, but optically it just looks better to me. If I was lowered, I might run a 35...but as long as Im not, I'll stick w/ running 40 series.
You know Im a pic *****
Stock comes with 245/50/16 or the 275/40/17. If you want to keep over all diameter or circumference the same, go with 275/35/18. If you want a taller tire in the rear, the 40s will work, your speedo will be off by 2.5 mph, faster.
Front and Rear
7.0" ..... +35 to +40 mm .... 215, 225, 235
7.5" ..... +35 to +45 mm .... 215, 225, 235
8.0" ..... +38 to +55 mm .... 225, 235, 245
8.5" ..... +38 to +45 mm .... 235, 245, 255
9.0" ..... +38 to +56 mm .... 255, 265, 275
9.5" ..... +38 to +56 mm .... 255, 265, 275
10.0" ... +38 to +48 mm .... 265, 275
From the sticky, is that what you are looking for, or talking about the 40 vs 35?
Use the http://www.discounttiredirect.com/d...nfoTireMath.jsp calculator, get all the information there, thats what I used.
Originally Posted by M6WS6
Front and Rear
