Wheel fitment question
Ok I have been eyeing up a set of wheels, spec are 18x9.5 with a +35mm offset, I know for the rear, these will be fine, however, in the front will these stay under the wheel wells, Also what type of grinding and pounding if any am I going to need to do?
Please post pics if you have this setup or something similar in the front.
This thread should explain what you need to do http://www.ls2.com/forums/showthread...hreadid=223590
I read the post thanks for the help, however the post does not even metion the front. So I refer back to my original question
will a wheel with a +35 mm offset in an 18x9.5 stay under the FRONT wheel well?
