315 should use a 12 inch wheel
Per Good Year a 315/35ZR17 fits on a wheel 10.5 to 12.5" in width and the "ideal" size is 11".
Use the "specs" at tirerack as a guide.
http://www.tirerack.com/tires/Spec.j...e1=yes&place=2
Originally Posted by 99blancoSS
Well I was and did that, but then I called Fikse and they were like you need a 12
I run 17x10's with Sumitomo 315's. Use Tire Rack for a guide or call the tire manufacturer for specs. Most tires recommend 10"-12"
Good luck
For some REALLY strange reason FIKSE, has way stricter wheel and tire recommendations . . . I can only assume it is race car driven . . .
For example they REFUSED to build a 9" wheel with a 275 tire mounted on it . . .
Next time I'm buying my wheels from one source and tire from another . . .
so what is the smallest width you can have to fit a 315 a 10inch? also will an 18X10.5 fit a camaro with 315's? or will there need to be mods done? sorry if it feels like i jacked your thread, but this wheel thing i cant seem to understand, and i thought this went well with ur post
I put the 315 Sumitomos on 11" TTIIs. They look like they fit easily. Actually, the tire doesn't bulge over the lip of the rim like the fronts do. I am thinking maybe I could go wider if I wanted to. It just doesn't look the same as the 245s on the front on 9.5" wheels.
ok well it looks like I'm about to make a deal on some wheels- 18x9.5's and 18x10.5 Fikse's. Will the front work? They come with 265x35x18 and 295x35x18 tires on them. I dont like the tires so what would be best? I have 275x17 on the front now. Will a 275x35x18 fit the front end? what about a 285? Also would a 305 be better than a 315 on the 10.5? Car is not lowered. Has SLP pro rate springs and Koni's on standard perch.
275/35/18 is just about perfect on an 18x9.5" wheel...
295 is about as big as you can get comfortably onto the rears due to the lack of very many 305 tires available in 18" sizes.
You might could squeeze a 315 onto the 10.5" but it will be tight and vary by tire.
