Hoosier DR Results
Hoosier DR Results
I keep meaning to post this.....
On my initial trip to the track with the blown stroker motor, I cut a 1.9+ 60' with my 315 Nittos (smoking). I borrowed a set of 11.5 x 27 / 16 MTs & cut a 1.62. The next time out I was running my new Hoosier 335/35/17 DRs and cut 2 back-to-back 1.60 60's! And that was with a gear change from 4.10s down to 3.40s. (in a 4,000 lb car with only a 3200 stall).
So if any of you are considering getting them, you will NOT be dissapointed! Oh, and they hook just as good on the street too. Hooisers ROCK!
What rim did you use for the 335 tires? i like the look of these, and a friend just bought some, but I don't know if they will fit on my car...my current 275-40-17MT ET Street Radials suck for traction on my 17X11 rims...I need more tire.
SDB
SDB
SDB
SDB
They are quite a bit wider than Nittos, like almost 2"!!! I had to beat on the inner fender a little more, and I had to "roll" the fender lip too (just used a plastic hammer & worked on it for an hour or so). I mounted them on my 11 x 17 ZR1 wheels & they fit fine. I'll try to post some pics later. The end product is going to have mini tubs so I can tuck the whole tire inside the wheel wells. They stick out about an inch right now.
