Guys with 17x11 +50mm offset ZR1's enter. - LS1TECH
Thread Tools Search this Thread
Old 06-02-2006, 12:49 AM   #1
Default Guys with 17x11 +50mm offset ZR1's enter.
what did you have to do, if anything, to get the wheels to fit on the rear? BFH mod?
hbeykirch is offline   Reply With Quote
Old 06-02-2006, 08:10 AM   #2
tbs98z's Avatar
I BFH modded in a few places(inner fenderwell)and rolled the fender(just in case)
tbs98z is offline   Reply With Quote
Old 06-02-2006, 09:02 AM   #3
I have 'em (Grand Sport offset). For me it was 1) a lot of the BFH, 2) ground down the bump stops some, 2) rolled the fenders. Every car is a little different & depends on what your ride height is and suspension set up too. Also I think TA's have a little more room than Camaros from what I here.
Cyborg is offline   Reply With Quote
Old 06-02-2006, 09:12 AM   #4
3521SS's Avatar
+1, BFH is your friend.
You might want to cut down your bumpstops too. My wheels loved to hit them when I went over any halfway large pothole in the road. Also, buy a panhard rod if you dont have one already, it will keep the rear from swaying as much around corners.
3521SS is offline   Reply With Quote
Old 06-02-2006, 09:22 AM   #5
UMD_Jesse's Avatar
Location: Fairfax County, VA (You know you're here when you see the bad roads)
Difinitley grind down the bumpstops!!!! thats the only thing I had to do to mine. The rims will hit the bumpstops everytime you jack the car up by the chassis, or even if you hit a bad pothole. Test fit the rims and you will see where it hits.
UMD_Jesse is offline   Reply With Quote
Old 06-02-2006, 09:35 AM   #6
chupr0kabra's Avatar
1) Centered rearend with adjustable panhard bar
2) BFH
3) Rolled fender lips
4) Trimmed back the mounting plates for the bump stops
DO NOT GRIND DOWN OR REMOVE YOUR BUMP STOPS!!!! They are tapered for a reason (the Z28/Trans Ams are more pointy/tapered than the SLP bump stops). You need them! Removing or altering the bump stops themselves is asking for problems (sliced sidewalls, more fender rubbing, etc.)
-Mike
chupr0kabra is offline   Reply With Quote
Old 06-02-2006, 06:00 PM   #7
95formulalt1's Avatar
i did nothing 50mm off set in back
95formulalt1 is offline   Reply With Quote
Old 06-03-2006, 12:22 AM   #8
Bear's Avatar
Mine fit fine for the lip. I have the SLP Bilstein/Eibach combo. Now as for the BS, its rubbing on the inside of the rim. I need to get an air tool and do some grinding of the bs. Its either that or get some spacers.
Bear is offline   Reply With Quote
Old 06-03-2006, 12:25 AM   #9
anyone with an lt1 bird wanna chime in?
Old 06-03-2006, 02:10 PM   #10
i have them and you gotta do the same stuff that every one is saying but i cut my bump stops of and have never had a problem with the inner side of the tire and im runnig gsd3s that are much wider than most 315s...now the outer fender was a different story
skatinjay27 is offline   Reply With Quote
Old 06-03-2006, 05:12 PM   #11
Quote:
mines is an lt1!!
Old 06-03-2006, 05:19 PM   #12
TECH Cry Baby BOSS APPROVED!
BFH, APHR. Running combo since April 2003 with no issues.
Urban Legend is offline   Reply With Quote
Related Topics
Thread Thread Starter Forum Replies Last Post
camaro Pilchenstein Vehicle Classifieds 18 01-04-2014 11:22 AM
delete ELDIABLO Generation IV Internal Engine 0 10-30-2013 05:45 PM
...... gtslowm6 Non-Automotive Classifieds 7 03-05-2013 02:13 AM
delete noobtolsx Vehicle Classifieds 19 01-11-2013 10:11 PM
Tags
17x11, 1995, 50, 50mm, camaro, mm, offset, zr1
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
