pro star write up
pro star write up
I know there is a lot of work to put pro stars w/ 325s on a Trans Am. But are there any write ups with pics of how to do it? Rolling the fender, beating the wheel well.. etc etc... Backspacing.. ALSO.. Can it be done without grinding the calipers? I really DO NOT want to grind the calipers. With such nice Z06 braking..
Originally Posted by FormulaFire
It's Upgraded to Z06 4 piston Calipers front and rear and Z06 braking system.
Zinc washed KVR slotted rotors all 4 corners 13" Front/11.9" Rear
Originally Posted by LS69TA
Nope. You'll have to grind the rear calipers to fit Prostars.
Centerlines will fit, but they don't have the ideal backspacing..they'll stick out past the fender. You can shell out a little extra $$ and get Bogarts. Steve @ SJM --> can hook you up with a custom setup designed however you need them.
It'll still drive like normal. You may end up rubbing the bottom of the fenders with the tiresif you hit a good bump or something, that's about the only negative I can think of.
