HP Evo 18x9 front & back
Looking for advice from those of you who are running HP Evos in 18x9 both front & back.
Will 275/35/18 tires work on the fronts? Any rubbing issues?
Thanks,
DMark
Thanks,
DMark
Originally Posted by 2000taws6
That is the perfect size for front and rear. You can rotate them and they wont rub.
I'm asking because TireRack and others recommend running 18x8 in the front with 245/40/18s.
Thanks for the reply..., anybody else have any experience with 18x9s all the way around?
DMark
got me?
The guy I got them rims from said they were 18x9.5" When I check web sites I only see them 9.5" on 19" rims. I ran a tape measure through it at and it come up 9.5". I know that is not the most accurate way to measure them, but it's the best I got right now. I measured it from where it rolls in on both sides(like Summit Racing catalog says how to measure).
I know it doesn't help much........sorry.
first of all you can only get 18" rims with a width of 9 inches, the 19's you can get 9.5 inches width
Modified, you cannot measure a rim like that, thats why your reading is incorrect.
With a 18X9 inch rim go with a 275 or 285!
I have 19x9.5 HP Racing HPR5's on all four corners on my car with 275/30/19 tires. I have no rubbing issues at all and the car is lowered as well. The only problem i have is the 19" 275's were substantially narrower than my old 275/40/17 KDW's.
I might step up to 285's with the 19's to offset it. Has anyone else noticed this with larger diameter tires in regards to width?
