before and after...ss wheels
yes i repainted the silver first then waited about 30 mintes to dry then went back with 2 coats of black and toped it off with about 3 coats of silver
they will be switched between my 2 z's they will first be on my white one...then in about 3 weeks they will go on my polo green.
Who makes that silver paint? It seems to be a very close match to the original silver. Did you mean that you topped them off with three coats of clear after the black?
scotch brite each wheel took me a little over 2 hours...the i simple used wax and grease remover sprayed the entire wheel silver metallic...then we let dry for 30 and taped off inbetween the spokes and lip...painted black let dry for 30 peeled tape off and then sprayed with clear...let dry overnight...
that silver i took to my local paint shop and after about 15 close matches of metallic silver we decited on this one...its a tad lighter but damn near the sam...its hard to find silver with that much metallic in it
ima post up a pic of the 2 i havent done next to these so yall cansee this diff in the silver
o and you can see the over spray inside the wheel...that will come off...havent decited if i want the inside black or clean it off and make it silver...i thnkin silver as i dont wanna overkill the car with too black of wheels
Daniel, thanks for the writeup. One more question. Is the silver you used available in an aerosol can? I would really appreciate the specs on the silver metallic color since it is so close to the original. You honestly can't tell the difference in the two colors in the first picture.
