Proper pressure for the 275-40/17
Old 07-16-2006, 05:14 PM
Don B 02 Z28's Avatar
Default Proper pressure for the 275-40/17
Hi Gang,
Just curious, what kind of air pressure you guys/gals are running in the 17's???
I just up-graded to a set of the ROH ZR6 17inch wheels on my '02 Z28 and I'm in the process of getting the last two new BFG 275-40 KDWS'ss installed. So, I'd like to make sure the pressure stay good in 'em.
I want to remember the ROH 17 in my x '96 Impala SS was running like 45psi in them. But, they were only 255-50's. So, what are you guys w/ the SS'ss running in the 275-40'ss???
Thanks,
Don
Attached Thumbnails Proper pressure for the 275-40/17-mvc-017s.jpg
Old 07-16-2006, 06:22 PM
stevethepirate's Avatar
look at what it says on the tires... it will give you the max pressure, dont go to the max.
32-38 PSI and you will be golden.
Old 07-16-2006, 07:05 PM
GETGONE's Avatar
The door tag on my SS says 30psi cold for the 275/40/17 tires though I generally run 32 in them.
Old 07-17-2006, 09:07 AM
LS69TA's Avatar
I run 32 front/ 28 rear. Seems to work decent on mine.
Old 07-17-2006, 12:40 PM
Dal1as's Avatar
I run about 33 or 34 psi in the front and 32 to 31 in the rear.
Old 07-17-2006, 12:44 PM
JoeyAnderson's Avatar
30-35 PSI cold here when the 17s are bolted on.
Old 07-18-2006, 12:02 AM
Thrasher245's Avatar
You go by what your car says it should be inflated to.
Old 07-18-2006, 03:48 AM
So, it looks like it's pretty much the normal pressure 32-35psi.
I was just trying to avoid startin some strange wear patteren on these new (hi $$$) BFG 275-40/17 KDWS'ss.
Thanks, for the replies.
Later,
Don
Attached Thumbnails Proper pressure for the 275-40/17-mvc-018s.jpg   Proper pressure for the 275-40/17-mvc-019s.jpg
