Fucked up my car like an idiot.
My alignment is REALLY off after popping a curb quite hard because I did not drive safely. My left front rim has a bit of damage to it and the car pulls heavily to the left. All I want to know is how badly do you guys think I fucked my car up, I'm already furious at myself so please refrain from ripping into me, I just want to know how bad it COULD be and how much it MIGHT cost me at a MAXIMUM.
do u have any vibration? you could have bent your rim. the cause of the severe pull could be a bent/broken tie rod. or at worst maybe a bent/broken LCA or hub. if its the first one, it wont be expensive and you could probably do it yourself, if its a hub or LCA it might get a little pricy and/or difficult.
Have a mechanic check it out. Depending on how hard you hit, there could be some bent parts . . .
www.fixrim.com might be able to fix the wheel.
Well to update the situation I have the lifetime alignment deal with Firestone so I took it in, they fixed the alignment and that was that. Ended up not costing me anything except a lot of pride and some aesthetic damage to my rim...which on the bright side gives me an exuse to invest in some new ones. Thanks Xsta and Michael.
