Anybody run 315/35/18s
I'm looking into getting 18 x 10.5's rear rims and running
35 series 18's rather than the 30 series because the 30s would be shorter than my front tires by about 1/2 inch,
so I wanna know if these tires would fit, I'm expecting to do the BFH mod.
pat
pat
Well, that is close to being a 27" diameter tire if I'm not mistaken. It should fit, I know people have gone all the way up to 28"+ tires. Are you lowered? What offset on the wheels?
And what front tire size do you run?
Originally Posted by z28pat
NO,
I'm not lowered, and the wheels would be either 50 or 53 offset,
I'm running 285 40 17's in all fours right now.
pat
pat
You will mess up your ABS if you run mixed matched height tires.
And 27" will not clear in the front.
As for wandering all over the road. I have 315's all around and it just really depends on your alignment and of course the condition of the road.
To me the worst part was that the wider tires would pick up more debris and throw it up. That's more annoying than anything.
It's ok to run 2 different sizes as long as the difference in diameter is not too large. My car has approximately 0.4" difference in height between front and back (275/40R17 & 295/35R18) and the ABS works perfectly.
I agree about the wide tires, my tires pick up everything on the road and throw it up onto the body, its a little annoying but not terribly.
69 Ta--100% Correct. I Run 315-35-18 Rears And 2 Inch Drop...my Paint Is So Messed Up From Sticky Tires Flinging Every Rock Into My Fender Wells..and My Paint Is Black..but For The Thread ? Dont Run Taller In The Front Due To Abs Problems And Ive Seen 24's On An Ss Before..so Antthing Is Possible My Friend.
Originally Posted by 69TA
Try driving with DR's all around. Sounds like a high school kid trying to get his girlfriend to come to the bedroom window
Originally Posted by gfastls1-sj
i would go with 315/30/18. thats my setup right now and my car is lowered. a lot of bfh and im prety sure u need to change ur LCA to tubular. also ur going to need a adjustable panhard.
pat
IMO there is no real difference between 295 and 315 it's the width of the wheel that will pull the tire one way or the other.
I would not go with 35's in 18 too tall.
Go 295's all around so you can rotate your tires. Or 295 front with 315 rears.
Do like Turo and use four 18" rear Z06's
Which by the way I have for sale. (four OEM GM Z06 rears)
Here is a pic of my car with 315's all around!!!
In case you are also worried about going wider in the back I also have fender roller tools for rent.
I am running a 295/30/18 tire in the rear (10.5" rim) and a 265/35/18 tire in front (9.5" rim). My rears have ~45mm o/s and I don't have any rubbing issues what-so-ever. I am thinking about trying a 315/30/18 rear tire next while either staying with the 265/35/18 tire in front or going to a 275/35/18. A 315/30/18 and 265/35/18 have almost identical diameters.
Here are a couple pics....I have more on my site
and you have an awesome looking Hawk too.
pat
