Pissed off at Weld wheels, anyone have this problem?
Old 08-19-2006, 06:41 PM
blind527's Avatar
Default Pissed off at Weld wheels, anyone have this problem?
So I put the new 3.25" ARP wheel studs in, and have the front runners mounted on the rim, and find out the holes on the wheel are too small. Went to check the drivers side *worked on passenger side first* to find out they won't fit on that side either. So, it's not a crooked wheel stud problem, it's the problem that the holes on the wheels are too small. Has anyone had this problem? My dad and I drilled out the holes more, and it's better, but we need a bigger drill. I'm super pissed right now, as I wasted all this money on something that's supposed to fit.
I bought the 15x3.5 with a 1.75" backspacing.
EDIT: I can put the stock wheels on without a problem. There is still plenty of meat left on these 15x3.5's, so I'm just gonna drill the hole to make it bigger.
Old 08-19-2006, 06:59 PM
TS6
TS6's Avatar
Whoa, WTF are you talking about? The holes in the rims are much larger than the studs, are you sure you got the right bolt pattern?
I've had issues getting cheap wheel lugs to go into the holes in Welds, but it wasn't the wheels fault. You got something really weird going on there. Post pics if you can.
Old 08-19-2006, 07:11 PM
blind527's Avatar
What do you mean WTF am I talking about? I ordered a 4.75 offset from them, and they aren't fitting. Since I already mounted tires on them, I'm screwed.
I just went out and measured it......The box says 4.75, but the actual pattern is a 4.5.......They sent me the wrong bolt pattern in the right box...Now I just have to drill it out...
Old 08-19-2006, 07:16 PM
DanZ28's Avatar
Yeah don't drill anything on the wheel or the lug nut will be loose in there, bad idea. The holes on the wheel should be much larger than the studs are. There are two bolt patterns on the weld wheel, make sure your on the right ones!
I just today installed the ARP 12mm x 3" wheel studs in my front end and put my new Weld skinnies on and they fit perfect.
Dan
Old 08-19-2006, 07:18 PM
DanZ28's Avatar
My Welds came with both 4.5 and 4.75 bolt patterns. What part number Welds do you have?
Dan
Old 08-19-2006, 07:19 PM
blind527's Avatar
WLD-96-54200. On Summit, it shows for the 4.5 bolt patterns. I believe a 4.5 should work on these as well...The box says 4.75.
Don't tell me a 4.5 won't fit, and I'm stuck with these now because I got the wrong ones and mounted a tire to them.
Old 08-19-2006, 07:34 PM
DanZ28's Avatar
A 4.5 will not work. regardless of what the box says, you just ordered the wrong wheels so no reason to be pissed at Weld for it. You should have ordered the WLD-96-54270 . I have Draglites and they have both bolt patterns on it so they are different. Since mine has both patters on it I can see how far off they are on the 4.5" pattern. I would NOT try to drill them to make them work, just to dangerous IMO...
Dan
Old 08-19-2006, 07:35 PM
blind527's Avatar
Yeah, I do have a reason to be pissed at Weld for it, the box is clearly marked with the WRONG bolt pattern which sent me the WRONG wheel. I ordered the 4.75 bolt pattern, but I was sent this.
When I put the order in, it was the correct part number, but now the number is showing it as a 4.5 bolt pattern.
Old 08-19-2006, 07:40 PM
DanZ28's Avatar
BTW, the holes are not to small, they are off set (in closer to the center of the wheel compared to a 4.75 pattern). You know the lug nuts are supposed to fit in those holes fairly snug (no slop at all). There is really no way to drill thos holes and make it right!
Dan
Old 08-19-2006, 07:41 PM
blind527's Avatar
Dan
Summit won't let me return them, so now what? See if someone will trade? Doubt it.
Maybe I can trade someone for a set of Draglites for the front, but a Draglite/Prostar combo would be ugly.
Old 08-19-2006, 07:44 PM
DanZ28's Avatar
Did you order direct from Weld? If they sent you a part number that you didn't order then I would be pissed to. If you oredered through Summit, be pissed at Summit and call them up!
Dan
Old 08-19-2006, 07:46 PM
blind527's Avatar
Dan
Summit. I'm just pissed at everybody! I e-mailed them and see what they can do, but I can't drive with those wheel studs in on a stock wheel...
Old 08-19-2006, 07:47 PM
DanZ28's Avatar
yank the tires and buy the right ones. If you already drilled the holes out, they are probably garbage now. If they are not drilled, just try to sell them, i think Mustags use a 4.5" pattern, not sure.
Dan
Old 08-19-2006, 07:49 PM
DanZ28's Avatar
If your receipt shows the correct part number and they sent you the wrong one, they should replace it. If you drilled it then your SOL I would think.
Dan
Old 08-19-2006, 07:50 PM
blind527's Avatar
They are drilled just SLIGHTLY, you can't even tell if you look at them. Fantastic, $350.00 dollars down the drain!
Old 08-19-2006, 07:51 PM
blind527's Avatar
The thing is, the site showed a 4.75 bolt pattern when I ordered them. AFTER I ordered them, the part number was for the 4.5 bolt pattern.
Old 08-19-2006, 07:54 PM
TS6
TS6's Avatar
I figured that was what happened. I'm sorry to say but you have some nice shiny new paper weights there. Once a tire is mounted to them you are dicked, it even says this on the rim. The fact that you tried to drill them (worst idea ever) just made it worse. Thats why I always check my Welds before doing anything. I've been through many many sets of welds, and had a couple damaged right out of the box. Always check and test fit first. Order some new ones and chalk it up to an expensive lesson....
Old 08-19-2006, 07:57 PM
DanZ28's Avatar
Do you have your online receipt? what does it show? Are you sure you didn't accidently pick the wrong one since they are right next to each other?
Put your lug nut in the hole. if it's loose at all they won't work and Summit can't resell them like that..
I hope it works out for you, i know very frustrating though...
Old 08-19-2006, 08:15 PM
blind527's Avatar
It's not loose at all, still perfectly solid.
Old 08-19-2006, 08:19 PM
boondiggys's Avatar
didnt you think that something was wrong when you got out your drill and started cutting on brand new wheels??
Quick Reply: Pissed off at Weld wheels, anyone have this problem?
