Ford 9inch-C5 wheels
I have a custom width 9inch with moser axles. But I think I have a problem with the axles. When I put the disk rotor on the axle, and then the C-5 wheel, it barely engages the axle hub. It looks like these axles have a shorter hub. I measure 3/8", and factory camaro is closer to 1/2". The hub fits in the wheel without the disk rotor there. Did I get the wrong axles? Can I run these wheeels without the hub in the center? Thanks
