what offset to get??? zr1's
Old 09-23-2006, 05:28 PM
WhosNXT's Avatar
Default what offset to get??? zr1's
My buddy has a 97 z, he is getting black zr1's and need to know what offset to get. He is goin to put the eibach sportline lowering kit. Should he get the 56mm offset or the 38mm? Thanx for n e help.
Old 09-23-2006, 07:15 PM
TECH Cry Baby BOSS APPROVED!
Urban Legend's Avatar
For the rear it should be 50mm offset on the 17 x 11. Its a nice fit and does not stick out like bigfoot tires.
Old 09-23-2006, 07:53 PM
Black1997T/A's Avatar
What size wheels is he getting? If He's going with 17x9.5 all around, I'd recommend the 56mm offset... Its perfect for that size wheel. If He's going with the 11" wheel out back I'd suggest what Urban Legend said.
Old 09-23-2006, 08:44 PM
Donohue96M6Z28's Avatar
for 11's i'd go with 50 mm
but with 17x9.5's i would also go with 50mm over 56mm, the 56mm stick in a little too much imo. But if you only can choose from 38 or 56, I would pick 56 for sure.
Old 09-24-2006, 07:30 AM
casey02ws6's Avatar
Yep - 56 front, 50 out back. The 50 in front would be perfect if they made it. Mine are inset a little too much - I will probably run a small spacer.
Old 09-25-2006, 03:18 PM
Xsta Z 28's Avatar
38 mm offset 9.5" wheels fit perfect on F-Cars. My Fikses are 38 mm. . . . . Now, since you want to drop it 2" . . . . maybe the 56 mm would suit you better.
Old 09-25-2006, 03:25 PM
bearcatpride's Avatar
You never miss an opportunity to showcase your sweet ride do you?
Old 09-25-2006, 03:59 PM
Xsta Z 28's Avatar
Yep, pic ***** I be!
Old 09-25-2006, 10:10 PM
Wow You're right. With the stock ride height, those 38mm wheels looks nice.
