tire pressure on M/T ET drags
Yes sir, they are rim screwed but tubeless. I have see people run as low as 8-10 psi in et drags but I am not too fond of that. Mine hook fine at where I run them so why run any lower.
I would post this up in the drag racing tech section but unless you're running 9's, IMO you shouldn't need to go under 11psi, if you're not hooking, you'll have to work on your suspension because that low of a psi on a heavy car makes it unstable on the top end and will slow you down a bit also up top.
