1" wheel spacers
Old 10-01-2006, 01:23 PM
blacksskid07's Avatar
Default 1" wheel spacers
hey does anyone know where I can get some 1" wheel spacers for my 01 ss?
Old 10-01-2006, 01:31 PM
BrandonDrecksage's Avatar
might want to check the correct forum....like the wheels section.
Old 10-01-2006, 01:49 PM
NHRAMAN's Avatar
Location: Vancouver,[KITSILANO].B.C. Canada *WestCoast*
Lightbulb
Search "Wheel Adapters" ...
Old 10-01-2006, 05:57 PM
02TransAm/Batmobile's Avatar
im pretty sure summitracing.com has some, if your going to do that i would recommend upgrading your studs too, . . . jus ask the mods to more your thread, .. they sometimes automatically do it anyways, . .
Old 10-01-2006, 06:37 PM
Danny2tek's Avatar
I'm sure he just meant you might get a quicker response if it was posted in the right forums.
Old 10-01-2006, 07:07 PM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
orangeapeel's Avatar
That is what he meant. You can't transfer emotion over text very easily. I will move this thread for you. 1" spacer is pretty drastic though. Mr. Gasket has a decent variety, but it might be something that you need to get a template and have one made out of billet or something. It will be hell on your studs for a 1" spacer. You might want to grind some caliper material off.
Old 10-02-2006, 10:02 AM
Fulton 1's Avatar
If you're looking for something 1" wide then it should be an adapter and not a slip-on spacer. By "adapter" I mean the kind that has its own pressed-in studs - you bolt it to your hub and then bolt the wheel to it - in your case the bolt pattern on the hub and the wheen would just be the same. If you want to do it right then talk to Andris at Skulte.com - he can build you just about any sort of spacer or adapter that you want and he does excellent work.
Old 10-02-2006, 12:43 PM
thanks alot guys, i'll have my new zr1's on soon and the spacer
