welds and M&T
welds and M&T
alrite i need help guys. if you have this setup or no about it let me know. my first question is can i run the 325 50 15 tire from M&T with 15x10 drag lites and the 7.5 back spacing on a lowered car about 2 inches. i think i can but i dunno about the 325 tire on a trans am. my next question is what is everything that i need to buy with this setup.
thanks
thanks
thanks man. now i no i can aleast put them on but now i need 2 know what else i need. extended wheel studs (what length), lug nuts (what size), and is there anything else that i would need for this set up to work with 15x10 drag lites in the rear with a 325 50 15 M&T Radial. just the rear i am getting for now so thats all i need to know for now.
thanks
thanks
you will prob need to get some spacers im sure. but this is what somebody told me on here as for stud size and lug size.
you will need a shank style lug nut 12mm x 1.5 thread size
1.300-1.380 shank length
.679-.687 shank diameter
ARP wheel studs with 5/16 spacers.
Hope this helps you man but this is what i was told to do to my car. please somebody chime in and atleast tell this guy if this is correct.
You're gonna have to massage the front inner fender a little,roll the lips(if you're lowering it). 5/16 spacer(as said above) and grind on calipers(no biggie), I ran the stock studs for a long time befroe I put the 9" in,the long shank SST lugs catch pretty good(no problems for 5K+ miles or on several other fbodies I've had with the same setup)My car is only lowered an inch in the rear but I have plenty of room. I 60' in the low 1.30's so the tire is up in the fender a little during launch and hasnt rubbed any yet. I've had this setup for a while and havent had any poblems. Heres a coupla old pics os when I did it
